Do You Reallly Need a Skid Plate?
ACD Racing
Postby ACD Racing » Fri May 29, 2015 11:04 am
Do you really need a Skid Plate for your Dirt Bike?
Skid Plates: Do I REALLY need one?
Short answer, YES.
Need more arguments to be convinced? Here you are:
1. Most dirt bike riders will inevitably say riding without one is not worth the risk. The cost of a skid plate is small compared to what you’d have to pay to replace your cases, shifters, and brake pedals .
2. One stone will easily put a hole in your casing, make you lose all your oil and seize your engine. Let’s not talk about how much that will cost you.
3. Adventure anywhere with trees? One wrong stick and you’re pushing your bike back to the truck!
4. If you ride a lot, or anywhere around rocks, a skid plate is a no brainer. Don’t learn this lesson the hard way!
5. Would that gravel or branch have damaged your oil filter? If your bash plate is doing its job, you’ll never have to find out!
6. Bash plates are NOT for fashion (although some say your bike looks unfinished without one). Look at any other plate and see the scars. Each dent represents a time that it saved you . After one ride, you’ll see all the disasters that were prevented.
7. Don’t be another trail horror story, #ProtectYourPassion with an aluminum skid plate from ACD Racing Parts.
Ok, you’re convinced. So then do you go with Aluminum or Plastic skid plates?
Aluminum Skid Plate vs Plastic Skid Plate
1. Try this analogy: I'm going to hit you in the chest with a shovel. You can hold up a thin sheet of something for protection. Which material would you rather have: Aluminum or plastic ? Exactly!
2. Ride though rocks? You better have an aluminum skid plate
3. Live where the mountains are? You’re going to need aluminum.
4. Come anywhere near a boulder, aluminum is what you want between you and a hard place.
5. Consider yourself a basher? Better go with aluminum.
6. Think aluminum is too loud? Place pieces of an old yoga mat or high density foam between the plate and the frame to quiet it. Most riders get accustomed to the sound quickly.
7. Plastic may be light and quiet, but it can’t hold up to the rough stuff. Aluminum skid plates’ weight and price may seem excessive, but if you nail one wrong place, it becomes an obvious necessity.
8. Check out ACD Racing Part’s skid plate collection and find the right fit for your bike today!
http://www.acdracing.us/blog-acd-racing-parts/do-you-really-need-a-skid-plate-for-your-dirt-bike/
ACD Racing U.S.
"Protect Your Passion"
as82
Re: Do You Reallly Need a Skid Plate?
Postby as82 » Fri May 29, 2015 1:26 pm
When buying a skid plate, if you choose to...consider some additional items in respect to the specific plate you get.
Can you "easilly" access your oil drain plug?
Are there any other bolts the plate will prevent you from accessing (water pump perhaps)?
Is the mounting system sane....or will it need my to hold three things place while screwing a fourth to get it mounted?
How much does this thing weight vs how often to you expect to take a hit vs how rich are you (Carbon fibre is cool but pricey)?
brewrabb
Postby brewrabb » Fri May 29, 2015 1:35 pm
http://www.emperorracing.com/About_us.html
BC company, if you shop local.
'78 XR75, '77 PE250, '81 KX125,'82 KX125, '85 CR500, '98 KX250, '04 KX250F, '05 KX250, '07 KX250, '09 SX150,...?
Registered users: Bing [Bot]
